It is currently Tue Sep 29, 2026 2:19 pm
 Post subject: Connector Ends?
PostPosted: Thu May 07, 2026 9:32 am
Do these connectors from patch panels go as connector ends? I busted open the double rj45 to show what's inside. The double 25 pin connector has gold color inside, but wasn't sure if that piece goes as a connector end.
 Post subject: Re: Connector Ends?
PostPosted: Thu May 07, 2026 11:56 am
I have a less whimsical flow chart I made from when I was working at a scrap yard.
Yes those are both connector ends. It may be pretty easy to pull the jack pins out at this point if you have a pile of gold plated pins, just bend and slide out.
PostPosted: Thu May 07, 2026 1:20 pm
Love the flowchart! Thanks guys
