It is currently Sat Nov 07, 2026 12:20 pm
 Post subject: Better to depopulate?
PostPosted: Thu Aug 10, 2023 10:24 pm
I have several of these boards that come out of a box of sheet aluminum. I will remove the metal bracket on the right, but there isn't much to these. There is the female pin connector on the left, a handful of ICs and the two socketed flatpacks.
I wonder if I would be better off to strip the ICs and flatpacks, break off the female pin connector, and then pull those coax connectors to throw the brass in my bucket to sell locally and toss what's left in scrap steel.
The yellow caps aren't tantalum either.
What would this be classified without the metal bracket and without the two flatpacks?
PostPosted: Tue Sep 15, 2026 9:22 am
Yeah. Remove the bracket. Take the brass. Remove the Socketed ICs. But leave other chips. Take female edge connector. Then submit what is left as High Peripheral.
That is what I would do if I depopulated. Which. I don't do as a rule. But. Am aware of.
PostPosted: Tue Sep 15, 2026 10:42 am
Can the steel be removed from the ports without knocking them off?
If so, remove the steel, leave everything else, high peripheral
PostPosted: Thu Sep 17, 2026 7:13 am
Thanks. Marked141. I saw that. As in your response. I was just attenpting to answer the depopulation question. I as a rule do not depopulate. As you have expressed in many post. I am in agreement with your opinion. High Peripheral. With little effort. Yet many members are trying to squeeze that blood out of the turnip.
What is your opinion on my suggestions to depopulate a few components and still maintain the High Peripheral grade?
Again. I would do it your way. But. How many members ask about depopulation?
PostPosted: Thu Sep 17, 2026 10:17 am
If you're trying to remove ICs I think you'd hit a downgrade pretty quick as I'm assuming the ports are heavy and the board is fairly empty. If you're removing the ports you're losing a little bit of gold and a bunch of weight so maybe you could lose several ICs.
But that's a bunch of work you don't have to do.
Steel is the only thing here I'd try to remove. It looks riveted so just get what you can without or destroying the board, if a little got left behind cause it had to be cut instead of unscrewed then that shouldn't affect anything.
All kind of moot though, 3 year old thread ¯\_(ツ)_/¯
PostPosted: Thu Sep 17, 2026 1:35 pm
I only respond to unanswered questions to gain any educational value.
Which I have just acquired.
Marked141. You have been at this e-scrapping business way longer than me.
And. I am only a casual e-scrapper. But. That doesn't mean I must be an uninformed e-scrapper.
I hope other forum members are getting thier online education at the:
University of Boardsort. Com
There are many fine professors here with thier Phd. in e-scrap.
PostPosted: Tue Sep 29, 2026 6:32 am
Update on this board and some others out of similar boxes. Interesting that you guys are commenting on these just as I'm getting around to finishing them. I've retired but I've just had a lot on my plate.
First is the box these came in isn't aluminum at all! It's plastic! I have about six of these so I thought I had some great sheet aluminum about 1/8" thick!
I popped out the socketed ICs, drilled out the rivets for the steel, and then removed the ports. I haven't checked yet what metal the shroud on each one is, but either way I just figured it's weight that Boardsort doesn't want. If there's gold inside I'll either throw it in pins or connectors.
Because there is a lot of empty area on these, I'm thinking of cutting that off to reduce the weight and hopefully upgrade what's here.
Thoughts on that? I've done that before with some boards that were only half populated.
PostPosted: Tue Sep 29, 2026 8:43 am
Cat's been digging into old posts and I miss the dates sometimes and get wrangled into thinking I'm helping on a new post <3
At least you popped back in.
Probably need to see the board as it is now.
PostPosted: Fri Oct 02, 2026 10:02 pm
Those old threads really do come back from the dead when someone bumps them. A current pic would settle whether it still makes high peripheral after all that stripping.
