It is currently Fri Sep 25, 2026 7:39 pm
 Post subject: Breaking boards
PostPosted: Fri Sep 25, 2026 8:33 am
I have a large national manufacturer that wants to give me boards.
However, some of them are proprietary boards and a previous waste company sold them online. So now they won’t hand them over until the boards are broken.
Anyone have suggestions for doing this at scale?
 Post subject: Re: Breaking boards
PostPosted: Fri Sep 25, 2026 12:40 pm
Depends on what broken means.
If broken means broken, well just snap them.
If broke means can’t work, the easiest way is to over-volt the board not explaining that further for liability reasons. But I’ve done that often enough.
If broke means shred.
You’ve got an issue on two fronts. You need a book-and-binder level shredder or an actual materials shredder.
And it becomes a refiner’s commodity. You can’t sell eScrap shred easily for cash.
PostPosted: Fri Sep 25, 2026 12:45 pm
They just want to break them in half but that’s easier said than done by hand and with hundreds of them.
I suggested simply defacing the boards with spray paint but they didn’t feel that’s sufficient so trying to help them stop accumulating and start handing the material over once prepared.
PostPosted: Fri Sep 25, 2026 1:17 pm
I’ve seen a guy on YouTube somewhere that used a large press to crack 50+ at a time.
Honestly if the value is worth it to you just find a metal or concrete step and snap them with your foot one or two at a time.
PostPosted: Fri Sep 25, 2026 2:07 pm
Maybe spraying them with salt water. That will "break" them.
